Author Topic: part name  (Read 2807 times)
manuel
part name
« on: July 25, 2010, 05:51:00 PM »
what is the name or part # of the valve on the firewall to the fuel regulator? the people at autozone don't know what it is
manuel r
part name
« Reply #1 on: July 25, 2010, 07:19:00 PM »
Its just a solenoid valve... it closes when the engine is re-started hot to keep fuel pressure up. Its not really a critical part, is it giving you problems?
bhazard
part name
« Reply #2 on: July 26, 2010, 05:06:00 AM »
Ditch it and run vac source straight to the regulator, you'll be fine.
manuel
part name
« Reply #3 on: July 26, 2010, 03:02:00 PM »
it was giving me problems it ran for 10 min. then died after a day it started for another ten min. i was checking the grounds and vacum hoses i tried to pull the hose that goes to the top of it and brocke the niple i unpluged the whole thing sprayed starter fluid and run good with out it.
manuel r
drbob
part name
« Reply #4 on: July 27, 2010, 07:24:00 AM »
manuel, how did those lambo hinges word???  The Capri world is waiting to know.
AUSTRALIAN Shepherd
manuel
part name
« Reply #5 on: July 27, 2010, 04:42:00 PM »
drbob     i had to buy some equipment to make them my self to sell them at a better price i still need a mill/lathe combo to do it faster and,i just moved  and i found out i dont have 220v anywhere but im still working on making some  ill send u a private message to let you know a bout the price  i think russ wants to sell them im not sure but ill work something up with you.
manuel r
