Author Topic: High idle  (Read 7552 times)
tennesseeguy
High idle
« on: October 31, 2009, 01:35:00 PM »
Hello everyone, i have a '93 capri and i no when the engine is cold it will idle a little high, but when mine gets warm it still idles about 1500 rpms, would anyone know why it idles so high? Thanks
High idle
« Reply #1 on: October 31, 2009, 07:03:00 PM »
Idle control valve on passenger side. mine does same thing and too lazy to change it...LOL
High idle
« Reply #2 on: October 31, 2009, 08:12:00 PM »
Hey Gost! Not to be picky but idle "air" control valve. If you don't say completely, it comes back with a "what". We both know what you mean.  Gus
High idle
« Reply #3 on: October 31, 2009, 09:52:00 PM »
theres a big flathead screw, on the throttle body
on top, its in a hole.. turn it in, to idle down and vice versa..
this is your idle screw,
 it probably is your idle air controll... you need a new one..
its silver and sits on the left side of the intake, above the alternator...
 ask russ (caprityper) he may have one for ya ...
 ... joe ....RCI...
High idle
« Reply #4 on: November 01, 2009, 06:17:00 AM »
NA and turbo are the same?
tennesseeguy
High idle
« Reply #5 on: November 01, 2009, 02:22:00 PM »
Thanks for the info guys, if i let it sit about 30 mins it idles down abit. ill look at the idle air valve i was wondering if it had on, now if i turn the big flathead screw and it sits for awhile it idles to slow. I thought at first it might be the coolant temp sensor for t he computer, but i dont really know for sure.
High idle
« Reply #6 on: November 01, 2009, 03:51:00 PM »
mine idles fine on start up..
at 1500 once car is warmed up.....sometime at 700 but rare once car is hot...
99% sure its the valve for mine. mine also drips coolant sometimes from it so it needs changed regardless..plan on rerouting the coolant line to the TB at the same time
tennesseeguy
High idle
« Reply #7 on: November 01, 2009, 03:56:00 PM »
thats exactly what mine is doing too. And ther is coolant runs threw the idle air control valve?
High idle
« Reply #8 on: November 01, 2009, 04:01:00 PM »
yep thats how it knows it at temp and works...
i think
delhiboy3732
High idle
« Reply #9 on: November 02, 2009, 06:50:00 AM »
I swapped the IAC from my NA to the XR2 and its the same part number. Yes, I had the same problem and now the NA idles high and the XR2 just fine.
tennesseeguy
High idle
« Reply #10 on: November 03, 2009, 07:20:00 AM »
well got it fixed the coolant lines going to the IAC were stopped up had to install new lines,i appreciate all the help from everyone. Next project is valve stem seals.
tennesseeguy
High idle
« Reply #11 on: November 16, 2009, 02:05:00 AM »
Well heres an update, i think the IAC has gone bad , now it wont idle up at all when its cold, and after it gets warm i have hold down the gas a little to get it started but it runs fine once its started and when its cold it idles at 800 instead of 1500, it had been idleing at 1500 then dropping down to 800, and the check engine light is on, any thoughts anyone? Would anyone happen to have a good one to sell?
High idle
« Reply #12 on: November 16, 2009, 01:35:00 PM »
pull the code and see what it is....that will tell ya for sure.
tennesseeguy
High idle
« Reply #13 on: November 16, 2009, 01:47:00 PM »
How do i pull the code?
High idle
« Reply #14 on: November 16, 2009, 03:42:00 PM »
http://teamcapri.com/capri-gi/ultimatebb.cgi?ubb=get_topic;f=3;t=000445;p=1
there is a pic here from rocket...
short out plug he circled and turn key to the on position but do not start..
count the blinks...it will pause then blink again..thats the second number..then repeat until u turn off. code list is on there as well
