Classifieds => Capri Parts => Topic started by: Jacob on November 13, 2009, 08:37:00 AM
Title: need turbo manifold
Post by: Jacob on November 13, 2009, 08:37:00 AM
looking for a turbo manifold that will work with a te04 turbo
Post by: Gostlrs on November 13, 2009, 01:15:00 PM
that has to be made....i believe
Post by: 1992xr2 on November 13, 2009, 04:35:00 PM
Get one for a d16 civic, it nearly works.
Post by: Gostlrs on November 13, 2009, 04:58:00 PM
what needs done to it?
Post by: Jacob on November 14, 2009, 10:01:00 AM
All I need is the manifold I can get everything else
Post by: Gostlrs on November 14, 2009, 11:31:00 AM
there are no direct fit ones..so u need to make it yourself
Post by: Jacob on November 14, 2009, 02:57:00 PM
cant I make an adapter plate or something that will work
Post by: Gostlrs on November 14, 2009, 03:14:00 PM
you can always make something...
most are using the hybrid turbos so the mounting is easy
some are starting to switch over to the 14b/16g turbos and welding on a new flange to work.
if you can weld or have a friend who can. you can figure something out
Post by: Jacob on November 15, 2009, 01:43:00 AM
how much would a used turbo cost me to make it easier
Post by: Gostlrs on November 15, 2009, 03:50:00 AM
you can find 14b cheap...just need to look around. DSM guys swap them out all the time and want little in return..
can handle 16 PSI all day. RCI is running one and love it
