My cooling fan does not appear to be coming on.
My 91 N/A has 134000 on it. Runs great, but the dang cooling fan does not seem to be coming on. The engingine seems to run about 2/3 to 3/4 up on standard gauge but has not gone redline or even to top end of Hot white line.
My wife's 93 N/A fan runs properly so I know mine should run the same.
I've reviewed previous posts and tried several of the tests and tricks. Ignition on, remove spade fitting at end of thermostat housing and fan should come on RIGHT? Wrong, but I do hear the relay tripping on and off when I remove and plug in the spade fitting.
I thought it was fan but I jumpered the fan to the battery and it runs fine.
Tried cleaning fittings as suggested in one post but nada.
Any suggestions?
