Author Topic: Hardtop window gaskets  (Read 3552 times)
Snigalfriz
    • 1991 NA Capri
« on: April 19, 2013, 09:51:00 AM »
Has anyone remove the windows from the hardtop and replaced the gaskets?  I had to repair extensive hail damage to mine and would like to remove the windows to complete the repairs.
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
Chicken
« Reply #1 on: April 20, 2013, 08:00:00 AM »
Side glass has pieces of rubber (that are the same triagne shape as the glass) pulled over the edges of either piece, then the glass is fitted with adhesive.  The rubber piece is channeled like a "U" ad hugs the glass. It is effectively nonfunctional as a gasket, perhaps for reducing wind noise, mainly for the finished look.
You "may" be able to remove the rubber if it is pliable and you are very patient. Try not to use metal tools because of the risk to the glass.  Getting it back on wil be even harder.
The other option is the cut the glass out of its adhesive.  Which may be the easier thing to do in the end.
Snigalfriz
    • 1991 NA Capri
« Reply #2 on: April 21, 2013, 03:07:00 PM »
Any thoughts on the rear glass?
2003 Lincoln LS
2014 Chevy Cruze LT
