Author Topic: I need a new radiator fan  (Read 4268 times)
Snigalfriz
    • 1991 NA Capri
« on: October 26, 2011, 05:18:00 AM »
Folks,
What radiator fans are you using to replace our old fans when they die?
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
« Reply #1 on: October 26, 2011, 05:40:00 AM »
Either a junkyard or Russ@RooSport replacement, or a Flex-A-Lite
« Reply #2 on: October 26, 2011, 06:22:00 AM »
I have a couple in stock!!  CapriTypeR@Gmail.com....
« Reply #3 on: October 26, 2011, 06:47:00 AM »
Not trying to knock russ, but seriously give rock a shot once in a while, you'll be surprised by the coverage lists for the 323.
 http://www.rockauto.com/catalog/x,carcode,1431649,parttype,2181
Worse case scenario you transfer just the motor over.  Plain Motor new runs about $35 from them less shipping.
Snigalfriz
    • 1991 NA Capri
« Reply #4 on: October 27, 2011, 04:57:00 AM »
Are our fans, push or pull, and do you know what size fans the stock fans are?
2003 Lincoln LS
2014 Chevy Cruze LT
« Reply #5 on: October 27, 2011, 04:58:00 AM »
They are pull-type
Snigalfriz
    • 1991 NA Capri
« Reply #6 on: October 27, 2011, 06:23:00 AM »
thanks
2003 Lincoln LS
2014 Chevy Cruze LT
« Reply #7 on: October 27, 2011, 04:17:00 PM »
All fans mounted behind the radiator are pull types.
Snigalfriz
    • 1991 NA Capri
« Reply #8 on: October 29, 2011, 05:57:00 PM »
I found out it isn't the fan, it is either the wiring, fuse, or relay.  When I connect the fan directly to the battery, it runs great.  When I disconnect the temp lead on the thermostat housing, the fan still doesn't run.  When I remove the "cooling fuse" the fan still doesn't come on.
Any ideas?
2003 Lincoln LS
2014 Chevy Cruze LT
« Reply #9 on: October 30, 2011, 04:36:00 AM »
I'd check/replace the relay - it's down behind the d/s headlight, I believe.
Have you checked all the fuses including those under the dash? Check for power at the relay too.
Snigalfriz
    • 1991 NA Capri
« Reply #10 on: October 30, 2011, 05:31:00 PM »
I hear the relay click.
2003 Lincoln LS
2014 Chevy Cruze LT
« Reply #11 on: October 31, 2011, 05:02:00 AM »
Check the wiring to the fan...
1) disconnect the connector to the cooling fan relay, should be 4 wires, yellow, black, green/red, yellow/green.
2) Put a test wire between the yellow/green and black pins of the connector, turn ignition on.
  2a) Fan on verifies the fan power wiring, you probably have a bad relay
  2b) Fan off means wiring or voltage issues
     2b1) Ignition off. Remove the test wire. Use ohm-meter to verify relay connector black wire has continuity to ground - open means damaged wire or connector or ground connection
     2b2) Use ohm-meter to verify relay connector yellow/green wire has continuity to cooling fan connector yellow/green wire - open means damaged wire or connector
     2b3) Use voltmeter to verify cooling fan connector yellow wire has 12 volts when ignition is on - 0 volts means damaged wire, bad fuse,
If all this testing passes, and if you disconnect the wire to the temperature switch, and the fan does not come on, then the relay must be bad.  Sometimes relays will click and still be bad internally
Yeah, I used to write electronic test procedures for a living for military avionics systems, I could easily make this a 3 page manual ;)
Chris
Snigalfriz
    • 1991 NA Capri
« Reply #12 on: November 02, 2011, 09:28:00 AM »
I replaced the relay, and it seems to have been the problem.
I had to get the cooling fan relay for a 1991-1996 Ford Escort (1.9L).  I got it at autozone, and the part number is 20453.
2003 Lincoln LS
2014 Chevy Cruze LT
