I checked the battery voltage today and it reads 12.4 volts with the engine off as to 14.4 volts running. I can't decipher the wiring for the charging circuit, but if the alternator is bad, wouldn't the battery voltage be the same running or off?
I went out yesterday to close the windows on the car and when I started it, the charging light didn't come on anymore. I checked the voltage across the battery with the car running and it's 14.4 volts. I have no Idea how the damn thing fixed itself!
Quote from: hairhook on August 21, 2022, 10:55:20 AMI went out yesterday to close the windows on the car and when I started it, the charging light didn't come on anymore. I checked the voltage across the battery with the car running and it's 14.4 volts. I have no Idea how the damn thing fixed itself!It may have just been a failure iin the regulator that sent a signal to the bulb but didn't affect the charging.
