Author Topic: WTB '91 NA Rt steering knuckle  (Read 4209 times)
PCFree
« on: July 04, 2011, 01:44:00 AM »
I replaced the bearing in mine, used a torque wrench and selection of spacers to set the preload and even with the correct pre-load, the hub still moves a little. Took it apart and found the race is loose in the spindle and there is a lip inside the knuckle where the race sits. Maybe it got hit and the race was imprinted into the casting?? May explain why some who have their bearings replaced have one burn out quickly? Anyways, I need a good knuckle to get mine back on the road! Write me at pcfree50 at gmail dot com.  Thanx!
\\"Computers & Cameras & Cars, Oh My!\\"
« Reply #1 on: July 04, 2011, 05:22:00 AM »
contact russ, I am sure he has them. Maybe Josh.
PCFree
« Reply #2 on: July 04, 2011, 01:18:00 PM »
How do I contact Russ or Josh?
« Reply #3 on: July 04, 2011, 04:34:00 PM »
Yell 3 times...
Once of them will be here soon. With the holiday they might be out & about.
« Reply #4 on: July 04, 2011, 06:08:00 PM »
Russ can be contacted at CapriTypeR@gmail.com I know for a fact he has knuckles, maybe 10 of them?
« Reply #5 on: July 04, 2011, 07:08:00 PM »
Yaaaaaawn..... Did someone yell my name 3 times???
PCFree
« Reply #6 on: July 06, 2011, 04:55:00 AM »
I tried emailing...do I have to email three times?
« Reply #7 on: July 06, 2011, 04:06:00 PM »
Your email ended up in my spam folder.....but I responded!
PCFree
« Reply #8 on: July 26, 2011, 05:03:00 AM »
Russ? Are you out there? I haven't heard from you since you said you were going to pull the knuckle three weeks ago! Are you trapped under a Capri!?!?
PCFree
« Reply #9 on: August 17, 2011, 02:09:00 AM »
Okay, it has been a month and a half and I am still without a steering knuckle. I don't know what is up with Russ, but I have never heard back from him. Does anyone else out there have one with a good bearing in it? Are they the same as the Mazda 323? Is there a difference between the Turbo and NA knuckle? Please help! The summer is almost over and I have not driven my Capri all year!
« Reply #10 on: August 17, 2011, 03:55:00 AM »
well if it helps I've also been waiting that long. too bad we all don't have dozens of cars and can wait on parts. I've got 1 daily driver and I needs it NOW!!!!
« Reply #11 on: August 17, 2011, 05:00:00 AM »
PC - I've emailed you several times and never received a response.........?
JJ - No excuse for you....I'm slacking. I will get the pictures today, and get them off to you....
« Reply #12 on: August 17, 2011, 08:26:00 AM »
thanks russ i appreciate it. i know you've been busy.
PCFree
« Reply #13 on: August 17, 2011, 06:37:00 PM »
Russ, the last time you contacted me, you said you were having internet problems and to send you my phone number, to which I did but never got a call.
