Will the Madzda 323 wheel hub mate up to our knuckles?
(1/2) > >>
mr_gr1mm:
I'm learning how to change wheel bearings, and I borked up my front wheel hub. The end of it is all dented from tapping it off the race and the corners are misshapen. Does anybody know if it can be replaced with a front hub off the 89 mazda 323? They look damn near identical to me.
For reference, this is what I'm looking at:
https://www.ebay.com/itm/171259298483?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=HxGaajKiSc6&sssrc=2349624&ssuid=q581KM2iTfO&var=&widget_ver=artemis&media=COPY
EShepherd:
It looks the same to me. Check and see if the '89 323 takes the same front wheel bearings, and if it has the same wheel stud spacing. If both of those are the same, I'd bet they are close enough to be made to work at least.
Rocketman:
I have not purchased one to check, but it should be the same as the Capri. It has the holes to bolt the rotor, rockauto lists the bearings as the same, and they have the same wheel lug spacing
I believe the Ford aspire hubs will physically fit, perhaps the axle spline too, but it is 4x100 and does not have a captured rotor
mr_gr1mm:
The seller is saying it does not fit the capri, but I call bs on that. It looks exactly the same and has all the correct bolt holes. I'm wondering if it even matters that I chewed up the end of my hub. Will it affect anything? it doesn't seem to play that much of a role so maybe I am just overthinking it?
EShepherd:
--- Quote from: mr_gr1mm on April 21, 2023, 10:39:08 AM ---The seller is saying it does not fit the capri, but I call bs on that. It looks exactly the same and has all the correct bolt holes. I'm wondering if it even matters that I chewed up the end of my hub. Will it affect anything? it doesn't seem to play that much of a role so maybe I am just overthinking it?
--- End quote ---
Got a picture? If you can clean up the high spots and it's not totally butchered, I don't see why not just send it.
Navigation
[0] Message Index
[#] Next page
Go to full version
