Author Topic: how do you bypass limp mode for more boost  (Read 3139 times)
89bigblazer89
« on: September 16, 2010, 12:08:00 PM »
hey i have  a 92 capri wanted to see if ther was any way to bypass the limp  mode my car goes into above 10 psi?
michael eaton
« Reply #1 on: September 16, 2010, 12:34:00 PM »
Bypass boost cut? You just unplug the boost cut switch on the firewall.
I will stress, ONLY do this if you have an upgraded ecu - the stock ECU will only support fuel up to 11psi of boost. Beyond that you run the risk of blowing the engine / melting pistons.
-Rocketman
89bigblazer89
« Reply #2 on: September 16, 2010, 04:39:00 PM »
well i wanted to push around that anyways but wher on the fire wall is it located? im racin it at a circle track tomarro so im trying to get as much out of it without destroyin it because it is my daily driver
michael eaton
rcdraco
  • Guest
« Reply #3 on: September 16, 2010, 05:02:00 PM »
Like he said, if you're really brave though you could run a manual boost controller for pretty cheap.  Ran 9.5psi on my capri without issue, torque is kinda a hard battle though while steering, even with power assist.
Not sure how much you can increase boost by without an exhaust though.  The stock might not be able to push much above stock levels.
« Reply #4 on: September 17, 2010, 06:42:00 AM »
Racing + More boost + no chip + daily driver doesn't really sound like a good equation to me, but hey its your car.
The boost cut switch is a hockey puck shaped sensor on the firewall. Here's a pic. Just unplug it.
bhazard
« Reply #5 on: September 17, 2010, 08:00:00 AM »
Anything beyond what the limiter allows is gonna destroy your engine, until you get a remapped ECU.
« Reply #6 on: September 17, 2010, 08:58:00 AM »
My opinion?  You can buy 1 of 2 things:  A chip, or a bicycle!  If you don't get a chip, and raise the boost, you'll need the bike to get around after you melt pistons from running to lean!
