Tech, Repairs, Upgrades > Non-Capri Usable Car Parts
Trunk Lift support; Source in Europe / Germany
(1/2) > >>
GermanXR2:
Hi, i need your help regarding both lifters in the trunk. The shipping and customs costs from overseas to Germany are higher then the parts itself.
Are any cylinders, maybe from other cars fit?
From my old BMW e36 convertible the top cover lifts nearly fits, only the force is to low. Its a Stabilus.
Does anbody knows sources in Germany or compatible lifters?
oring for XR2 with spoiler is:
Lift Cylinder
F2JY-76406A10-B
greywolf27030:
In the US, there are gereric lists that show lengths and lift power, you might try that.
GermanXR2:
Thanks for reply.
Where to find online?
I try Stabilus (German company), use the number mentioned from several parts shops, and nothing. Unknown number...
Compressed Length (IN)           8.13 (198mm)
Extended Length (IN)                   12.3 (312mm)
Stroke Length (IN)                   4.17 (106mm)
End 1 Type                                   BLADE (.256 DIA. HOLE)
End 2 Type                                   Ball Socket (Nylon) 10mm
Maximum Force (LB)                   72.0 (300N)
greywolf27030:
In the US, some parts stores can cross reference the info you have to obtain a new part.
Andotron:
Do you still have the old ones?  I had mine re-gassed for $20 each
Navigation
[0] Message Index
[#] Next page
Go to full version
