Classifieds => Capri Parts => Topic started by: azgtx on November 28, 2010, 07:39:00 AM
626 5th gear sets 55.00 shipped in US have 2 sets
VJ11 compressor housings and wheels 50.00 shipped in US have 2 sets
Clay
Clay, I am not familiar with the VJ11 Compressor housing thing.
I've not touched or researched anything to do with the turbo stuff.
Can you (or someone else) please give me the 4-1-1 (or a link) on why I need one of them?
Thanks,
Dave
Its the essential parts needed to create a VJ11/VJ14 hybrid, which is an upgraded turbo. You retain the stock turbine housing and replace the compressor with the VJ11 parts. IIRC it flows some ~30% more and it offers a nice gain in power, especially top end (doesn't feel like its running out of steam like the stock one sometimes does)
Bump for a great seller, and excellent prices!
Rocket hit the nail on the head..thanks for the bump Matt. These two upgrades are likely some of the best bang for the buck. The 14/11 hybrid does not quit at redline like the vj14 does...and brilliantly if I might say so.... and no lag on the bottom end. In getting just the cold side you don't have to buy a whole VJ11's worth of stuff you will never use. The gears are a twofold whammy..either increased fuel economy or a 10% bump on your top end.
Clay
Clay-
Put me down for a set of each. Paypal to follow.....
OK Russ that sells them out.
Thanks
Clay
With the VJ11 compressor you get about the same amount of air in CFM at 12lbs of boost as you do with the VJ14 at 16lbs. The more you compress the air the hotter it gets. Hotter air isn't as dense as cooler air so it robs power and you also have predet that comes with a hotter air charge and the knock box signals for retard to offset it which robs power.
As for the gear set I bought a set from Clay about 2 years ago. I graphed the RPM v.s. Speed and got about a 12% increase with the 626 set. There is actually a taller set that will work from the 323 Diesel but try and find one in the states. I have a very helpful Mazda parts guy that helps me find everything I need. All i need to do is come up with the money. The gear sets are real easy to do, I did mine when I had the trans out for a new clutch. It took about 15 min.
True on some cars. Our knockboxes are real primitive, and only work on/off. There is no gentle retard for it. Its more of an emergency thing for us
Phillip,
Still have the gear ratio graph?
That"s true. I've hit that point a few times mostly in spikes when I'm running high boost. It feels like the engine just shuts down. I have a cheap boost controller, when it first spools it spikes a bit. I'm building a new turbo now and porting the waste gate and exhaust housing. I got the compressor and snail from a company called "Turbos R US". It's an upgrade for the Subie's Much larger wheel, Suppose to be a TD04 16G. I'll see how it works.
I feel the knock box is VERY GOOD. Its not just an on/off. Its a good unit to graft into other cars when you want to add a turbo. But YES its primitive solid state stuff. Though I have only heard rumors of any ever dieing.
On the GT/GTX once you hit that Solid Cutoff, you have to reset the ECU. The Capri ECU is a tiny bit more modern. But I use the term modern in a subjective example. n The non turbo system seems to have gotten more attention.
Have you ever tested all the signals out of alll the wires during a roadtest on one Matt?
I've never heard of an ECU reset - Details?
Have you grafted the capri knockbox into another car? Wiring diagrams? I/O datalogs?
How did the nonturbo get more attention?
One was grafted into an early RX7, and I saw one used on a B1600. Wiring is in the book.
The non turbo dohc never had a US FED map until it was in the "Mercury" Capri and the Turbo map was merely extrapolated from the Mazda into more cells. *(theoretically more cells)*
Not sure that more cells were used in Australia or even what the ECU number is there. And I've never seen the grid for our B6T
Im sorry, where is this info coming from?
N/A Maps are the same size as turbo maps, and our turbo maps are identical to those used in the 323
People hacked all the ecus years ago. I don't have any of that info at all anymore.
Like I said the non turbo dohc never had a US FED map until it was in the "Mercury" Capri. There was no application with the DOHC in North America before.
The Turbo map was merely extrapolated from the Mazda into what I hear is a grid with more cells. I would suppose they can be the same size, sure! The knock is controlled by solid state, the advance is controlled mechanically, I don't think the map has to be any bigger or smaller. Are they the same number of cells across all generations?
How does the XR2 map compare to Craig's old B660 ecu?
!!WE'VE JACKED CLAYS THREAD. SHOULD ADMIN THIS TO A NEW THREAD!!
what year 626 are the 5th gear sets out of? do you still have a set available?
89-90....sorry I just saw your post. I can have a set this week for you. lmk
Clay
Got the stuff. It all looks fantastic, great seller!
I have one set each of these at this time..just in time for your summer road trips..same prices.
Thanks
Clay
Do you still have a vj11 wheel and housing. I leave for Cali on some infantry annual training getting ready for afghan but I'll be home on the 28th or so and if you'll hold it I WILL buy it from you when I get home. I'll even offer to pay a holding fee too
Pay for it now and it will be at your mail box by Tues or Wed.
cold side sold...still have the gears
Pm'd you
Still have a gear set
Back from Cali finally. Pm'd you
Any more VJ11 "swap kits" available per chance? I'd be interested in a $50 shipped deal if you can track down a good condition one at the junkyard!
Still looking...found one last week but the wheel was stuffed.
Cool mate... keep me posted! (http://smile.gif)
