General => General => Topic started by: randyshear on June 02, 2009, 10:22:00 PM
Does anyone have the correct rim bolt pattern for the N/A capri?
Hey Randy! It's the same for all Capris. Gus
Ok, I thought it might be.. Which bolt pattern is it though? I'm looking for rims today..
stock wheel is 4x100 14" wheel tires should be 185/60/14
you can go 205/50/15, 214/40/16, 205/40/17, or 215/35/18.
17 and 18 you are pushing it as there might be so rubbing on the read strut if you get the wrong offset. I have 17s on my capri.
Anthony,
the stock lug pattern is 4x114.3. 4x100 will not fit the capri.
whoops, just measured my bolts >< cause after i posted it, i thought it didnt sound right.
Hey Randy! There's been a bit of discussion in the past over wheel and tire combos. If yougo with a set of H&Rs it will tighten what will fit, so be careful in choices. I have on two '91s 15-6 wheels with 195-55 tires. both cars also have H&Rs. One car's wheels are factory '94 XR2 and the other aftermarket wheels. No clearance problem on either. some other forum members have 16inch and 17inch wheels. Get comments from them as well. Gus
i dont know about h&r, but i have ground control coilovers with a 2" drop.
17s on 205/40/17
no problems as all.
4 x 114.3 stud pattern
205/45/R16
1.25" drop on Lovell springs, koni shocks, still retaining original strut and perch hardware.
Severe scrubbing on wheel arch panel (front and rear) on tight sweeping turns +60Km/h
It literally took me months to find wheels to suit the car.
Would've taken a weekend if we were running 4 x 100 PCD
EDIT
major lapse of WTF
144.4?
I have never heard of 144.4???
4 x 114.3
Sorry guys, got a case of scatter brain and lethal does of caffine.
Thanks for pointing that out
