Author Topic: WTB: xr2 front swaybar  (Read 2380 times)
« on: July 13, 2011, 09:31:00 AM »
need good front swaybar and all bushings and stuff that goes with. put an oem ford kit on the ends in 2004, but that's all shot and the bolt is half rusted through....
« Reply #1 on: July 13, 2011, 09:34:00 AM »
Pedders or Energy Suspension
« Reply #2 on: July 13, 2011, 09:48:00 AM »
where do I get those?  and I was just in the energy suspension site and can't figure out what I need. What is the diameter of a stock swaybar?
« Reply #3 on: July 13, 2011, 02:06:00 PM »
I have a stock sway bar, if you want one of those....
« Reply #4 on: July 13, 2011, 04:12:00 PM »
yes how much with shipping to 28711? prefer no rust-- I have one of those     how are the bolt holes? any visible wear? this is for the big u shaped one under the car. if you can throw in 2 good bolts that'd be good till i can find where to source ne and bushings. right now it's a bit scary to drive, but it's all I got.
wish i could just get a cheap rust free red xr2.... new tires, needs alignment, needs new exhaust, needs new gas tank (exciting as the drip is inches from the big hole in the muffler and aimed right at it), new rear brake lines, new rear caliper, new rear rotor and pads.... ne front pads and pins, this is just what's been needed in the past week.
« Reply #5 on: July 13, 2011, 06:16:00 PM »
I'll try to dig up part #'s for you.
Sounds like your baby needs some TLC... needs less than mine that's for sure
