Tech, Repairs, Upgrades => Capri XR-2 89-94 => Topic started by: nachius on September 14, 2022, 09:00:00 PM
Alright I have all the bolts off and it's loose. Do I have to pull the front swaybar and/or crossmember brace to get it the rest of the way out? I searched and read most of the threads, but never found a good answer.
Ok can confirm you can get the oil pan off from underneath, although I'm not sure it is easier than pulling the engine. ;D
remove all oil pan bolts
remove lower motor mounts, I have the top passenger one already off from head/timing belt removal
jacked up engine/trans with board under the trans until the lower motor mount bolts pass the brace they run through
drop exhaust
From here the pan comes right off
