Author Topic: 1994 Capri Base A/C Compressor  (Read 2573 times)
NiteLord
    • 91Cap,94Cap,86FieroGT,94G.C
« on: June 27, 2015, 05:54:48 PM »
Does anyone have or know the correct Part# for a 94 Capri A/C Compressor. I have a 1991 Capri which I was going to use the compressor off of it but the hose's from the 94 Capri will not match up to the Compressor from the 91...I would use the hose's from the 91 but they won't match up to the port's on the 94's Condenser or  Evaporator..when they converted from the R12 to the 134A they must have changed the entire system...
Re: 1994 Capri Base A/C Compressor
« Reply #1 on: June 27, 2015, 07:48:57 PM »
I think they have a used one on roo-sport.com. I know Rock Auto carries a reman one. There's a thread under General forums that has a 5% Rock Auto discount codes. Just plug the code in the "how did you hear about us" box when checking out.
Did the clutch fail or the compressor wear out? Debris can plug the drier and even the expansion valve. I would change them too if spending all the money on a compressor.
Maybe retrieve the part # from RockAuto and you might find a cheaper one on eBay or Amazon.
« Reply #2 on: June 27, 2015, 08:06:05 PM »
Can you not just swap the compressor manifolds so the hoses line up?
« Reply #3 on: June 27, 2015, 08:08:28 PM »
On the compressor change that is correct but I would flush the whole system if the compressor is bad. Could be metal throughout the system.
