Author Topic: timing  (Read 3806 times)
rock-on
timing
« on: February 24, 2009, 02:08:00 AM »
does anyone know why i have to run my dist. so far advanced for my xr2 to run where it has good power,i had replaced the motor with a brand new short block B6T,the timing belt is on correctly all the marks lined up,could i have a bad cam.also it seems like the temp gauges read high but really it doesn't over heat,yes it does have a thermostat in it.  :confused:
timing
« Reply #1 on: February 24, 2009, 06:29:00 AM »
Hey Rock! Sounds like you need to back through the steps one more time. Something isn't indexed correctly.  Gus
timing
« Reply #2 on: February 24, 2009, 10:09:00 AM »
It does sound like you might have a cam one tooth off, double check that.
Also, what shortblock do you have? Check the crank pulley for wobble if its a smallnose crank.
rock-on
timing
« Reply #3 on: February 24, 2009, 02:46:00 PM »
thanks gus and rocket for the info,i got the short block and it was the small nose crank i had taken the old crank, had it checked and polished and put it in the new engine block beings it was bigger snout,if i find the stuff to change it over i will have a spare when time comes,but i have checked back and checked again with the cams being off but they seemed like they were lined up,i will check again just because it is not that time consuming and i could have missed something hell you never know i'm not perfect i'm human,mistakes happen.will let you know outcome.
timing
« Reply #4 on: February 24, 2009, 03:25:00 PM »
i think my pulley wobbles when running but feels strong and not move then the belt is off...
timing
« Reply #5 on: February 24, 2009, 03:38:00 PM »
What build date is your capri?
Your harmonic balancer could be worn out too
timing
« Reply #6 on: February 24, 2009, 04:44:00 PM »
Hey Rock! The harmonic balancer as you have found out does not swap between those two cranks, as long as the correct pulley is in proper place it should time. Also if you're not aware, the oil pumps do not interchange, so make sure you have the correct one in place. otherwise, no oil pressure.  Gus
rock-on
timing
« Reply #7 on: February 26, 2009, 11:23:00 AM »
found the problem,it was a bad harmonic balancer went to the u-pull-it today found another one put it on and problem fixed,timing is right on the money.thanks for all your help.   :D    :D
timing
« Reply #8 on: February 27, 2009, 04:22:00 PM »
how would i know what the build date is?
timing
« Reply #9 on: February 27, 2009, 04:23:00 PM »
Sticker inside driver's door
