Author Topic: New Pulley  (Read 2986 times)
LGCapri
    • 1992 Purple Capri XR2
New Pulley
« on: February 22, 2019, 11:08:11 PM »
The Capri needs a new pully for the water pump, can anyone send me a link to a replacement? I've found this one but I didn't know if it was the right one. https://www.autozone.com/external-engine/idler-pulley/duralast-idler-pulley/634098_658599_0
Trackerrrr
Re: New Pulley
« Reply #1 on: February 23, 2019, 04:35:52 PM »
That is definitely not a water pump pulley for a Capri. Water pump pulley has three mounting holes and is much larger in diameter. The link you posted looks like a idler pulley which is correct for a '91 N/A Capri and others.
« Last Edit: February 23, 2019, 04:39:01 PM by Trackerrrr »
Chris
Retired Air Force MSgt
LGCapri
Re: New Pulley
« Reply #2 on: February 23, 2019, 04:38:25 PM »
Thanks for that info, I don't have access to the capri as its being worked on for a different reason. I'll look for the pulley you described. thanks again
Trackerrrr
Re: New Pulley
« Reply #3 on: February 23, 2019, 04:39:58 PM »
Perhaps you are thinking of the idler? Water pump pulleys don't normally go bad but the idler pulley bearings do.
Chris
Trackerrrr
Re: New Pulley
« Reply #4 on: February 23, 2019, 04:44:47 PM »
Water pump pulley:
Generic idler pulley w/bearing (not Capri specific):
Chris
LGCapri
Re: New Pulley
« Reply #5 on: February 23, 2019, 07:07:55 PM »
I'll double check with my mechanic on what it exactly is, I'll let you guys know what he says. Thanks for all the help
Re: New Pulley
« Reply #7 on: February 26, 2019, 12:41:38 AM »
Closer, but no. The pulley you are looking for is a single v-groove pulley.
Did you find out what is wrong with yours? Like someone above said, it's not an item that generally goes bad or wears out.
I don't know of anywhere you could purchase them brand new, perhaps at a Mazda dealership.
Should be the same for the 89-93 Mazda Miata. They did switch to a 4-rib micro-v at some point but I'm not exactly sure when.
LGCapri
Re: New Pulley
« Reply #8 on: February 28, 2019, 06:32:17 AM »
The pulley was bent from the previous owner, but it was no fault of his own. He really wasn't a car person and didn't know much about the car, so I bought it off of him. And the 89-93 miata's have the same pulley? I'll look for it today and tomorrow (Taking a junkyard excursion). Thanks again
LGCapri
Re: New Pulley
« Reply #9 on: February 28, 2019, 01:07:45 PM »
Re: New Pulley
« Reply #10 on: February 28, 2019, 11:24:51 PM »
Yup those appear to be the correct pulleys
LGCapri
Re: New Pulley
« Reply #11 on: March 01, 2019, 07:22:10 AM »
Thank you so much, I'll order them now lol. You guys are great
