Tech, Repairs, Upgrades => Capri XR-2 89-94 => Topic started by: keyfoot on April 02, 2014, 02:32:31 PM
Howdy. Well I bent my driver side rear lower control arm, the adjustable one, and one of the bolts
There is two 8 1/2 inch bolts that hold the control arms together and in place, and I bent the one closest to the wheel, had to cut it out.
I'm having a hell of a time finding a replacement, found the lower control arm but not the bolt, can't find a suitable replacement at local hardware shops either.
Anyone have one, or know where I can get one?
Or know a suitable substitute?
Need it asap, its my only veichle
Do you have a Mazda dealer local to you? Those lower bolts suck.
FWIW those are lateral links back there, control arms are up front
Matt -
I'd be willing to go pull those bolts off the 88 tracer, if those would work. (I don't need much of an excuse to run over to Pull-a-Part!). What do you think? I could overnight em to keyfoot.
That? Would be amazing, so the tracer's will work? How much to have you get that for me?
I think its the same chassis so I'm guessing it might work. I don't know if its interchangeable w the XR2. Waiting to see what Matt (Rocketman) has to say. Pullapart.com has their part pricing in a drop down menu. Im guessing they'd charge the price for the sway bar link/pin ($3.90). I figure I'd drop the part and the receipt in the mail to you; you can send me back the cost of the part and postage. Gives me an excuse to turn a wrench at a junk yard.
Sounds like a plan, let's see what rocket man says
The tracer has drum rear, the bolts may be the same though. Not sure. They're a bear to remove in most cases
Mazda dealer will be able to help you for sure, for 88 323 turbo sedan, that had rear disk brakes.
Here's what I got. Does this look right? Its closer to 9" than 8.5".
http://i989.photobucket.com/albums/af15/grantduffield/IMG_1909_zps9853906c.jpg
couple others pics
http://i989.photobucket.com/albums/af15/grantduffield/IMG_1910_zps222f38b1.jpg
http://i989.photobucket.com/albums/af15/grantduffield/IMG_1907_zpsf00463f9.jpg
http://i989.photobucket.com/albums/af15/grantduffield/IMG_1906_zps51296612.jpg
http://i989.photobucket.com/albums/af15/grantduffield/IMG_1908_zps9f8b31da.jpg
ya that looks like it :D
My info is thus.
Mailing Address: 614 S Wayland ave 57103 Sioux Falls, South Dakota, United States
Phone number: 605 809 5961
USPS Tracking Number: 9114901230801516162275
Should be there on Saturday.
:o:
Thanks!
I had to get a few other things so the guys gave me the bolt/pin. so I only charged you $37.14 for it.
(jk)
I got the pic on Monday, sadly the lateral link came in and it was the wrong one, so still having to wait on that :-/
Sending of your compensation tomorrow.
Thanks for the help, I appreciate it.
Keyfoot is a straight up guy. Did exactly what he said he would. Thanks man!
