Author Topic: ignition switch help  (Read 2211 times)
Nate
    • http://www.myspace.com/nate111285
« on: August 04, 2009, 05:17:00 PM »
i hate to ask, but i don't have a manual at the moment...how do you get the outer piece off the ignition switch? i am having trouble getting my top column cover off.
-Nate
Phillip
« Reply #1 on: August 04, 2009, 05:46:00 PM »
Pull the bottom plastic trim. Put the key in and turn it to the on position. On the bottom there is a release that looks like a small button, Push it in with a drill bit or punch and pull the whole key and lock assembly straight out! Every thing pretty much is a take off after that!
Nate
« Reply #2 on: August 04, 2009, 06:06:00 PM »
Nice! thanks a ton!
