Author Topic: Service Manual Part 03-06 Starter  (Read 4073 times)
just2day_93CAPRi
    • http://www.mrmtv.org
« on: March 24, 2007, 08:13:00 AM »
Does anyone know where to find the Part 03-06 Service Manual on-line? On Tech Capri it jumps from 03-05 to 03-07.
Also, I'm trying to locate the starter - this is ridiculious - never haven't had one difficult to find unless on the bottom?
Thanks,
Ben
Ben \\\'93NA_AT (times2)
« Reply #1 on: March 24, 2007, 08:38:00 AM »
its directly under the intake manifold , on the driverside, mounted to the manifold support bracket and bolted into the bellhousing of the transmission
just2day_93CAPRi
« Reply #2 on: March 25, 2007, 12:15:00 PM »
Thanks Rocketman!
After posting, I went back and stuck my head down behind the engine and saw the round casing. Now the next key question: Do you have to remove the manifold to take it out - Surely not?
Most typical starters are only two bolts and not too big of a deal to swap - I just did one on a '91 Camry and it wasn't much too it.
It would be nice to see a drawing since most of the work will have to be done by feel unless I have to take off the manifold. (ugh - 3+ hours to do 45 minutes).
Does anyone have a drawing or the
Capri_SM_------_S03-06.pdf that is referenced as information on the starter? TechCapri.com jumps from S03-05 to S03-07. Don't know why.
« Reply #3 on: March 25, 2007, 04:14:00 PM »
http://fordcds.com/
^^download a service manual CD. It has all the info you need.
IIRC its 4 bolts - two on the transmission side, and two on the back.
I'm fairly sure you can pull it out without removing the manifold.
just2day_93CAPRi
« Reply #4 on: May 22, 2007, 09:38:00 AM »
Thanks Rocketman!
I'm downloading, downloading, downloading....
Big file !!
Looks like I can get my '94 Exploder 4x4 info too.
« Reply #5 on: May 22, 2007, 10:07:00 AM »
Dont thank me, thank the original poster - I forget who it was. Somebody stand up!
seriouswrong
« Reply #6 on: February 28, 2008, 05:22:00 AM »
I know this is yet another old thread, did all you Capri owners just disappear?
Anyways the fordcds site is now dead can anyone share the downloadable manual, I know about techcapri, but like the op said its not complete.
Thanks!
Tony Chamberlain
cl
« Reply #7 on: February 04, 2010, 03:36:00 PM »
just completed starter removal and replacement, loosen inside bolt, lower backside, then the two top ones closer to the battery, the bracket is a pain, about 6 bolts to take that off.  My starter or solenoid just went out, one morning it just didn't want to start.
