Author Topic: Source Gear shifter linkage Bushing  (Read 3764 times)
GermanXR2
    • XR2 Turbo
« on: September 17, 2022, 11:33:12 AM »
I need the 6 bushings "Gear shifter linkage bushing"........ I am desperate
Is there somewhere  a 3D file of the bearings avaliable to reprint, or a technical drawing with the dimensions?
In Germany the bushings are not available, at NAPA Online (ATM 0771303) I cannot select them as shipment, first 6pc. are available, on the next page it says "minimum quantity 12", these 12 are then also no longer available at the following next page (a circle). The service center dont want to help, they say got to shop.....
Any ideas?
nachius
    • formerly 91 n/a, now a 91 xr2 being built
Re: Source Gear shifter linkage Bushing
« Reply #1 on: September 17, 2022, 03:49:50 PM »
https://www.thefestivastore.com/ should have the bushings.
GermanXR2
    • XR2 Turbo
« Reply #2 on: September 18, 2022, 07:25:08 AM »
@nachius
Thanks a lot!
https://www.thefestivastore.com/product/shifter-bushing/28?cs=true&cst=custom
Question to the guys who replace already, do you need the "Long Shifter Bolt"? My Merc hat only 41K miles.
Did someone knows the origin parts number of the bushings?
it looks that the Festiva is equal to the european Kia Pride and the european Mazda 121.
« Last Edit: September 18, 2022, 07:47:14 AM by GermanXR2 »
« Reply #3 on: September 18, 2022, 08:34:41 AM »
The front shift rod has a rivet that must be replaced when replacing the bushings. That's the reason for the new shoulder bolt. You're correct about the models that interchange. Fords, Mercurys, Mazdas and Kias from that vintage all use the same bushings.
GermanXR2
    • XR2 Turbo
« Reply #4 on: October 09, 2022, 01:56:26 PM »
Should i replace all bushings?
Or are certain bushings subject to more wear and tear as others?
I think the rear ones, directly under the gear stick, are the easiest to replace.
« Reply #5 on: October 10, 2022, 08:23:47 AM »
Two of them are easy because there is a shoulder bolt holding them together. The ones of the front are the ones with the rivet. Depending on mileage the ones in the front may be gone. On high mileage cars I've seen where they changed the easy ones and the front one wasn't even there.
GermanXR2
    • XR2 Turbo
« Reply #6 on: October 10, 2022, 01:32:54 PM »
I had only 41.000 miles .....
JJCapri
« Reply #7 on: March 06, 2023, 03:49:01 PM »
yes, but we're talking (if original) 30 year old rubber. if there's any stress on those the second that brittle rubber gets some, it breaks.. so i don't think it's a miles thing as much as an age thing...
