Author Topic: question on low amp fuse box  (Read 1946 times)
David Duckett
« on: February 13, 2012, 12:01:00 PM »
Does anyone know if the low amp fuse box for a 91-94 capri interchangeable?
rcdraco
  • Guest
« Reply #1 on: February 13, 2012, 02:16:00 PM »
Technically it should be.  The only difference would be the wires going into the back for models with/without air conditioning.
I think the panel is also shared with another car but I'm not 100% on that.
David Duckett
« Reply #2 on: February 13, 2012, 03:08:00 PM »
ok that's good to hear, first my fuse box somehow got corrosion in it. i started losing systems left and right. some fuses had power and some that i figured were on the same bus had none.  I have replaced the 94 fuse box with a 92 but now i have less working than i started with..lol... i'm sure i have made some mistake in the connection or i have an ignition switch going.
« Reply #3 on: February 13, 2012, 03:37:00 PM »
91-93 were pretty much all the same, 94 had a bunch of different wiring elsewhere in the car, I could see the wiring being a little different. You should be able to make it all work though
I personally have not ripped out 91 and compared it to 94 wiring
