ok to start with no coolant/oil mix, comp. good, but the it is not blowing heat and it does not have a thermostat. the problem is the car gets to hot status but not overheated so what are some ideas to it.....will a clogged heater core cause it and does this motor overheat without a stat? and other suggestion is very welcome
