Tech, Repairs, Upgrades => Capri N/A 89-94 => Topic started by: Stickshifter6 on July 06, 2018, 06:56:10 PM
I have a 1993 Capri with manual transmission. For some reason in 2nd gear with steady throttle as the revs increase I notice the car hesitates than starts to pull like normal. It's never done this before I think I would of noticed it. Could this be related to a fuel issue such as the injector?? I haven't really noticed it in other gears
Could be fuel, if I were to start checking stuff I'd look at the ignition system first, a lot easier to inspect & could be the culprit.
-Spark plugs
-Plug wires
-Cap/rotor
Thanks for the reply rocket man, I will check that stuff also I noticed it's in first gear too so it's not one gear only
Could also be a small vaccum leak.
