Author Topic: Tail light repair/replacement and '94 panel  (Read 4569 times)
blue93
« on: November 06, 2009, 01:10:00 AM »
I'm looking for the rear panel that sits behind the tail lights of a '94. I
have '94 tail lights for my '93 and want to install.
Also, the tail lights I picked up both have previous melting issues. I have a
repair plan for the sockets, but the magnifying baffles have been melted in the
turn signal/brake light area. So the questions are:
1. should I look to replace the baffle or can I get away without them as long
as I vent the sockets?
2. has anybody tried this and are the bulbs bright enough without a magnifier?
3. Anybody want to buy a rare '90 Lebaron Convertible 3.0 SOHC Mitsubishi 6cyl, 5sp?
As most people know, the magnifier in pre-'94s is in the outer lens/housing.
I'm concerned that the heat from the standard bulbs will melt the more sensitive
plastic on the outer light housing of the '94 assembly. LEDs have not worked
for me on my '94, unless someone knows how to overcome the quirky electrical
things that seem to happen when they are installed. Thanks.
Mark
Stratosphere Blue '93 NA 5sp
Dynamic White '94 XR2
Radiant Red '90 LeBaron GT Vert 6 cyl 5sp and it’s FOR SALE NOW!
Frosty White '06 Vibe 5sp
Mark
Stratosphere Blue \\\'93 NA 5sp
Dynamic White \\\'94 XR2
Camellia Red Pearl \\\'10 Subaru Forester 5sp
« Reply #1 on: November 06, 2009, 03:12:00 PM »
normally there is a resistor that you can put inline with the leds to stop the quick flash problems. autozones normally sell them.
russ might have that light pnl. i never see the pnl with the lights for sale. if i did not have a donor car i would of never known it myself when i did my swap
blue93
« Reply #2 on: November 07, 2009, 04:09:00 AM »
So when you did your lights you wired in the resistor?  Thanks, I'll check it out at autozone.
Mark
Mark
« Reply #3 on: November 07, 2009, 04:58:00 AM »
when i used leds in the past yes...
running regular bulbs now..
i dont drive at night much with this car..so not worried about it yet
blue93
« Reply #4 on: November 07, 2009, 06:58:00 AM »
Got "load balancers" today at Autozone $12.99
Mark
Mark
« Reply #5 on: November 07, 2009, 07:36:00 AM »
should do it
tellerx
« Reply #6 on: November 18, 2009, 02:10:00 PM »
Ok so the 94 lights set up will go into a 91-93
« Reply #7 on: November 19, 2009, 12:04:00 AM »
yes...you need the panel that goes with it as well...which i never see when they are sold on ebay..the harness too unless you want to do some splicing as well
blue93
« Reply #8 on: November 20, 2009, 11:43:00 AM »
I just found one on eBay, but it was listed as a '96 Capri filler panel.  Not only did they get the year wrong, but they had it grouped with Cougar parts - go figure...
Mark
Mark
« Reply #9 on: November 20, 2009, 01:07:00 PM »
if its cheap...get it..then when you find the lights you will be in business
blue93
« Reply #10 on: November 20, 2009, 02:34:00 PM »
I got some lights.  First, I bought a pair and found after I got them that the left tail light had a cracked lense - just wasn't visible in the photo.  So then I found another left and the lense isn't cracked, but the housing is so faded it doesn't match the right one.
So whaddya do?  I tried armorall on the faded one, but they still don't match.  I thought about switching the lenses, but it looks like a sealed unit.  I think maybe I'm just gonna mount the ones with good lenses and keep working on the faded light.  Maybe try a buffer to rub out the faded black housing.
I'm gonna paint the filler piece black, so it'll be a band of black against the Stratosphere Blue. I think it'll be hip.
Mark
Mark
« Reply #11 on: November 20, 2009, 04:07:00 PM »
i painted the trim around my lenses and painted the other part black as well...
your right it looks yummy  :D
blue93
« Reply #12 on: November 20, 2009, 05:24:00 PM »
You're right - it does look yummy.
Mark
Mark
« Reply #13 on: November 21, 2009, 06:29:00 AM »
painting the lights was so easy as well...then blue painters tape slid in between the lens and trim..not one speck on the lights at all...
