General => General => Topic started by: kelly270 on October 25, 2009, 02:00:00 PM
Is the engine out of a mazda protoge' 1.6 a B6T?
Man, I was driving my car yesterday and all of the sudden, after running it through the gears, I noticed a sudden loss of power and it is running real rough, kind of like it lost timing. It just had a new timing belt put on... Any suggestions on how to check it?
no thats a newer engine. and if i remember its a B8 or BP version engine.
IIRC the protege never came with a 1.6. Always a 1.8 sohc or dohc depending on the model
yes it can be swapped but its not easy
The MX3 got a version of the 1.6 but it wasnt the same exact thing
Check for vacuum or boost leaks. #1 cause of problems like you describe
thanks guy, I will check for a vacumme leak tommorrow. Matt-I still have not yet installed all the hardware, I just bought a universal BOV from siliconeintakes. If I was going to like rebuild a motor and start with a stock 323 1.6 motor, do I have to change the crank along with the pistons to change the compression levels? I am thinking about building a new motor for my XR2, so I know really know what all has been done. I am hesitant about the motor in my car because of all the miles on the speedo. Mabe with enough money and time and a new motor I could run with the big boyz???
best off looking for another capri engine
Compression check yours see what shape its in.
Hey Kelly! Your best off looking for another motor or buy a new short block off of Ebay for $400. If you wrecking yard hunting for cars after august'91 build date or familiarize your-self the difference between a large snout crank and a small snout crank. your car should have a large snout cran. the short blocks on Ebay are small snout and will require you to get a pulley and other related hardware for that crank. Gus
so glad i got a engine and tranny in the yard for this occasion.
thanks russ and jessica! (http://smile.gif)
Thank her, not me! It was her car, I just brokered the deal!
--R
mucho thanks for the info guys, the reason I was asking about the protoge' was, I found a rebuilt head on line that stated 1.6 motor out of a mazda protoge', I am asking for more info. It was proffesionally done but not installed. Oh by the way, the reason for the lack of power in the XR2 was one of the f#**^ing injectors power source was hanging off the motor, lost the keeper piece, luckily my Beamer buddy found it and had a keeper on hand!! I always immediately think the worst. I will compression chck the motor! Probobly nothing even wrong with it! I just want to be secure before the boost. Thinkin' bout
BOOSTED
for a license plate!
gus- what do I punch into ebay to look for a shortblock?
Hey I'm getting ready to remove the power amp from the car to make room for gauges, anyone want one, you know for the premium sound package?
Hey here's a little sumptin, my car came with the front rotors and brake calipers off of a 1989 1/2 mitsubishi galant VR4 non-turb, and on the back -rotors and calipers off of a 1995 ford escort wagon. It stops well and they seem to work just fine, so far iI ain't run into any one.
I dont think they're VR4 rotors - those are too big to be used as an upgrade. Congrats though - you have one of very few Capri's with upgraded brakes. Perhaps the only one with upgraded rears.
The front should have the Galant (266mm) rotors and 14-22v Escort calipers.
I'm curious about the rear, the escort never shared a common bolt pattern. I dont know of any upgrade for the FWD, i'd like to see how they did it. I've heard of upgraded rears on a GTX, but they're setup more like the front so its a lot easier to work with
Hey Kelly! Ebay--parts and accessories--'91-'94 mercury capri. An outfit in Texas has them. Joe@ RCI customs has one in his car and I have a full motor from them in Janis. Full motor is no longer available. Don't know how many short-blocks are left but am planning on buying two or three soon. On your brakes: the fronts sound like the correct up-grade? the rears I question along with Rocket. Gus
Man this forum rocks!!!!!!
I don't actually believe any other forum in the world has as many people on it and is any where as active!
Matt- those are the "numbers" the guy I bought the car g
Snap some pics of your rear setup...we are all curious now
ditto!!
will do!!
Any one got a exhaust manifold for the xr2, I was tearing into the lifter project and took off the heat shield and the f'n thing is cracked, I tried looking on line and found one for the 1.6 miata turbo, will that work?
cant bopost until it get fixed, I just put in the rocket chip also this evening. Any info on he miata one, think it'll fit?
comes from a company named "addicted2racing",found it on ebay.
thanks
Hey Kelly! Nope!
thanks gus- I actually looked on the section in here for interchanging parts and saw that it didn't!
Any one got one for sale?
A exhaust manifold for a XR2?????
Hey Kelly! Is your manifold leaking or just cracked. Just about everyone I've seen is cracked only a couple leak or leak badly. Check the forum archives under XR2 dated 4-23-09 header. There are a couple of guys marketing a header. My last word with them is about $400. They would like several orders if possible. Let me know if you're interested, I'll try harder to dig up the cash. Gus
