Author Topic: Check Engine Light  (Read 3484 times)
Check Engine Light
« on: March 13, 2009, 03:04:00 AM »
please anyone know how to pull the codes?
i keep getting the light every once in a while and i want to figure out what it is without taking it to the dealer for a 70$ fee for 5 minutes of work.
D22A
Check Engine Light
« Reply #1 on: March 13, 2009, 01:41:00 PM »
i was gettomg that  from  throttle body sensor
i just chaged that
i will tell you that it's not oxigen sensor
do not even think about that
you can unplug oxigen senor and check engine light never will come on
1996 MT 3000GT LS
1993 CAPRI n/a
Check Engine Light
« Reply #2 on: March 13, 2009, 03:55:00 PM »
i got a new o2 sensor on it anyways.
i just want to know how to pull the codes...makes troubleshooting 1000 times easier.
it does not happen every day.
i notice it happens more in the mornings when going to work. never when coming home.
not every morning either.
it should be as simple as shorting out 2 wires and watch the lights when the car is on and not running....
Check Engine Light
« Reply #3 on: March 13, 2009, 04:25:00 PM »
It is as simple as that...theres a diagnostic connector on the firewall next to the evap canister
Check Engine Light
« Reply #4 on: March 13, 2009, 06:48:00 PM »
which plugs there are 3 on the firewal, what wires to short out?
that's what i been wanting to know
Check Engine Light
« Reply #5 on: March 14, 2009, 10:17:00 AM »
anyone?
Mike
Check Engine Light
« Reply #6 on: March 14, 2009, 05:31:00 PM »
it is the single yellow wire.
Mike 93Xr2
Check Engine Light
« Reply #7 on: March 14, 2009, 06:55:00 PM »
thanks
i got 15 and 25
now to see what those are
Check Engine Light
« Reply #8 on: March 14, 2009, 07:22:00 PM »
which chart do i use?
one said it was
15     Oxygen Sensor Voltage
25     FPRC Solenoid
the other
15 (O)No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
25   Knock sensor not tested (ignore if not pinging) - KS
i have a new O2 sensor in the car already. I think my crank wobbles some. it is not loose to touch but when running it appears to wobble. maybe thats causing it to fail?
Check Engine Light
« Reply #9 on: March 18, 2009, 01:21:00 PM »
anyone know which code tree i use?
