Tech, Repairs, Upgrades => Capri XR-2 89-94 => Topic started by: Gostlrs on March 13, 2009, 03:04:00 AM
please anyone know how to pull the codes?
i keep getting the light every once in a while and i want to figure out what it is without taking it to the dealer for a 70$ fee for 5 minutes of work.
i was gettomg that from throttle body sensor
i just chaged that
i will tell you that it's not oxigen sensor
do not even think about that
you can unplug oxigen senor and check engine light never will come on
i got a new o2 sensor on it anyways.
i just want to know how to pull the codes...makes troubleshooting 1000 times easier.
it does not happen every day.
i notice it happens more in the mornings when going to work. never when coming home.
not every morning either.
it should be as simple as shorting out 2 wires and watch the lights when the car is on and not running....
It is as simple as that...theres a diagnostic connector on the firewall next to the evap canister
which plugs there are 3 on the firewal, what wires to short out?
that's what i been wanting to know
anyone?
it is the single yellow wire.
Mike 93Xr2
thanks
i got 15 and 25
now to see what those are
which chart do i use?
one said it was
15 Oxygen Sensor Voltage
25 FPRC Solenoid
the other
15 (O)No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
25 Knock sensor not tested (ignore if not pinging) - KS
i have a new O2 sensor in the car already. I think my crank wobbles some. it is not loose to touch but when running it appears to wobble. maybe thats causing it to fail?
anyone know which code tree i use?
