Author Topic: I need littel helpp(avtomatic)  (Read 5643 times)
D22A
« on: September 11, 2008, 04:57:00 PM »
i have problem, my car works 900rpm ven its hot and is in P or N .but when I am puting in D or in R RPM-s gous down 780rpm or 790rpm and weel has vibration,and if you not braking hard car moving its works like if you driving menual and ou braking and tacking fut from the cluch  if some one nows how regulilait transmission please tell me
1996 MT 3000GT LS
1993 CAPRI n/a
D22A
« Reply #1 on: September 17, 2008, 01:28:00 PM »
Hellpppppppp
neeeeddd big helppp
some one can help my capri??????????????
1996 MT 3000GT LS
1993 CAPRI n/a
D22A
« Reply #2 on: September 24, 2008, 03:23:00 PM »
I  open  oil pan, I removed oil filter but i dont know how fix my RPMs, wen it's  in R car works on 550-600 RPm and has big vibration and in D it's works 800-850 rpm still has vibration and I think my cluch needs regulation, who knows what for is this bolt????
1996 MT 3000GT LS
1993 CAPRI n/a
« Reply #3 on: September 25, 2008, 09:40:00 AM »
You should have a qualified technician work on your transmission. They are very complicated and delicate.
D22A
« Reply #4 on: September 25, 2008, 10:26:00 AM »
I olready have new filter and new oil dexron 2, filter cost 24.99 and  oil 1 liter 4.95 . we need 4.0 liter or 4.5
1996 MT 3000GT LS
1993 CAPRI n/a
Xodus989
    • http://xoduslive.net
« Reply #5 on: September 27, 2008, 06:41:00 PM »
Did you even read his post?
And your car was just fine... You're supposed to move forward when in D with no brake...
D22A
« Reply #6 on: September 28, 2008, 03:38:00 AM »
i did, but I could not take car eny vere becouse  there was  no oil in  transmission, now I chainged oil and filter  and car runs geat and few day I will show to mechanic about RPMs
1996 MT 3000GT LS
1993 CAPRI n/a
D22A
« Reply #7 on: September 28, 2008, 03:40:00 AM »
and  when I read this post I olredy had my filter and  oil
1996 MT 3000GT LS
1993 CAPRI n/a
« Reply #8 on: September 28, 2008, 11:16:00 AM »
Hey D! I'm not making fun of your english but it is very hard to understand your thoughts that you're trying to get across to us in your posts. I read and reread this series of posts sveral times. Iniatlly I was going to respond to check your motor and transmission mounts because of vibration complaints but I realize you are saying the car does not move. What you are doing, changing the fluid and filter are the best thing that "you" can do. If that does not work, then a transmission rebuild is the next thing in order. Changing the clutch packs and examining the gear clusters and checking the fluid pump take advanced skills and knowledge that would be hard to learn in a fast minute in these posts. Please do not take my first statement as a put down about your language skills ,as it takes time. Who knows how long it would take to learn your mother language enough to converse with people.  Good Luck Gus.
D22A
« Reply #9 on: September 28, 2008, 01:11:00 PM »
I finished  changing oil, car runs great,  about my english i know its realy hard to understand  but I trying, car  runs and drives  great but only problem I have is that vibration, i cheked mounts, there is only 2 mounts right side and front, there is No rear mounts, only 1 bolt holding transmission, that 2 mounts are good.
i have new spark plugs very expensive $10each, I changed all of them, I just order  fuel pressure regulator becouse  fuel pressur regulatore stock cost 99$ and I payed 60 for this
an oil catch tanck, few days ago i was tinking I had voltige  problem I bout voltige stabilizer
I don't know I am spending money and i am doing nothing for  my primery problem
1996 MT 3000GT LS
1993 CAPRI n/a
« Reply #10 on: September 28, 2008, 10:50:00 PM »
Hey D! Glad to hear you are operating again. $10 for spark plugs(platinum) is a little steep. Recheck your mounts and there is supposed a rubber insulator as part of the rear mount. Also, are you having other problems? Or should I ask why the pressure regulator?            Gus.
D22A
« Reply #11 on: September 29, 2008, 07:57:00 AM »
I donn't know  it's  looks very old  and I ckecked  and it's not holding  fuel preshere  and  stock is to expensive and I tink  this one is beter,
I ordered  other things to carbon black  muffler, it,s will be delivered today  and oil catch can  and i can say I keep my capri UPDATE   :D    :D
1996 MT 3000GT LS
1993 CAPRI n/a
STE_6000
    • http://teamcapri.com
« Reply #12 on: September 29, 2008, 11:37:00 PM »
good luck with those mufflers, chances are ur gonna drag it. i dont know if you looked under the car at the bumper, but its flat, unlke most imports. so its going to sit that complete thickness right under the car bumper.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
dennis
  • TeamCapri Supporter
« Reply #13 on: September 30, 2008, 01:49:00 PM »
Capri transmission uses MERCON fluid!
Was 1991 NA but now 1994 XR2
D22A
« Reply #14 on: September 30, 2008, 06:08:00 PM »
I changed and i put castrol dexron 2 for fords and GMS  cars  only
1996 MT 3000GT LS
1993 CAPRI n/a
