General => Build Threads => Topic started by: JhonnyDaPirate on August 27, 2016, 05:00:06 PM
My very first build on my own have no idea what I'm doing . trying to figure out where theheck to add the transmission fluid to my 93 Capri 5 speed manual tan. Could really use a picture or video. Truly ignorant here
You need to remove the speedo gear from the transmission. That is the "dipstick" and the fill port. Just follow your speedo cable to the end, locate the 10mm bolt and remove it. The bracket may be stuck to the housing, so be careful when removing it. You don't want to snap the "tab" that the bolt goes through.
