Author Topic: Adding a turbo to my 91 sa2  (Read 7789 times)
Benno77
« on: June 01, 2009, 04:18:00 PM »
Hay i just a quick question on adding a turbo to my 91 capri NoN turbo engin. What is the best option when it comes to this? i have a farly good idea that iti is probably cheeper to buy a b6t engine and transplant it but i was wondering can i buy the turbo and manafold and add it to the excisting engine with out having to change much as i do not have a work shop in order to do much chopping and changing??
cheers ben
« Reply #1 on: June 01, 2009, 04:44:00 PM »
if you really want a turbo then sell yours and get an XR2.... thats the best option. by the time you buy everything you need you could of found a good deal on a new one.
there is someone using a NA engine on here and i am sure he will be here soon to post..LOL
it can be done for sure...but at the cost you want? thats the question
« Reply #2 on: June 01, 2009, 07:16:00 PM »
Hey Benno! It's a lot easier to get a turbo capri. The change-overs are tremendous and probably way more costly unless you have a crunched available and the crunch is in the rear. Hey Gost! You're gonna go through a learning experience like my-self. In Australia XR2s don't signify turbo cars. I'm still having problems with that.  Gus
Benno77
« Reply #3 on: June 01, 2009, 08:24:00 PM »
thanks guys.
i figured as much but wonted to be sure. Dont really have the dosh to be buyin another car as i am a full time uni student. So it looks like i will be doin some little stuff. thanks for imput
ben
« Reply #4 on: June 02, 2009, 04:37:00 PM »
yea im that guy and im posting...LOL
i built a high compression b6t with a b6 na shortblock but everything else i used was b6t.. including cams, head ,electronics, and turbo ect...it makes a fast b6t but without everything else from a b6t it would be pricy to build
find an xr2 turbo or 323gt gtx ,with a blown motor and swap your block and mate all the other parts to it.. thats what i would do. but i have space and lots of tools. so i do things a bit faster than some...i dunno look at what the miata guys are doing...i did ...joe
« Reply #5 on: June 02, 2009, 04:44:00 PM »
Still stuck with the stock F-type then...its a grenade bolted to a B6T
Zach Reisinger
« Reply #6 on: June 28, 2009, 08:10:00 AM »
I am purchasing a 1991 Capri n/t and wanted to make it turbo. So from this thread it seems I will basically use just my block and all the other parts off of an xr2 or 323 gt/gtx, but what about the tranny, does that need to be changed as well or can you use the non turbo from the b6? I would appreciate any help as I'm sure others here know it is pretty hard to find info on these capri's. Thanks and I look forward to hearing from you guys. Also if you know any other engine that can be fit into here please let me know, because I have seen a few capri's with 1.8l turbo motors in them, and I can't figure out what it came from.
« Reply #7 on: June 28, 2009, 08:55:00 AM »
trannies are different as well...
all the time and money to make it an XR2 you can buy one..just find an XR2 unless you are getting the NA for free
« Reply #8 on: June 28, 2009, 08:56:00 AM »
You can use the stock B6 tranny but you get stuck with a small clutch and they dont take abuse very well.
It is *easier* to get an XR2... or find an XR2 parts car to source all the parts from. You definately want the turbo tranny and clutch, and most of the rest of it goes along with it. You can use your block but gotta watch how much boost you run, the pistons are higher compression.
The BPT 1.8 turbo was only available in Japan...its about $2000 from an importer. Its a really tight fit and I wouldnt dare mate it to a B6 tranny. The tranny that it comes with is for AWD and generally useless to most of us.
The BP05 is the nonturbo version of that engine, its available in the states in many mazdas and the Ford Escort GT. Its a pretty solid motor making good power in n/a form and would really make a Capri haul without needing boost. Still just as hard to squeeze in though.
« Reply #9 on: June 28, 2009, 12:43:00 PM »
i still think an SR20DET in this thing would be sweet.
the silver top from the Nissan Avenir is a FWD and mounted the same direction. i think it could fit easy and your looking at 206HP stock at 7PSI. there is a ton of aftermarket stuff and getting it up to 250-300 is easy.
plus no one has done it!
« Reply #10 on: June 28, 2009, 01:15:00 PM »
Got any measurements? The BP is a small engine and it wont even fit without pretty extensive modifications to the framerail to give it clearance
« Reply #11 on: June 28, 2009, 04:19:00 PM »
« Reply #12 on: June 28, 2009, 04:22:00 PM »
Miata is RWD, dont have the same space constraints
« Reply #13 on: June 28, 2009, 04:58:00 PM »
how tough to make our RWD?
the GT-R is a tiny car. smaller then the 323 i think and it holds the SR20DET. i am sure it would fit. a friend of mine has a SR20 sitting around that he is gonna put in the 240sx i could get a measurement from that
the engine has been installed in a lot of cars. FWD AWD and RWD so there are several options available
« Reply #14 on: June 28, 2009, 06:22:00 PM »
Very, very tough to make RWD
would more or less need an entire donor car be it an RX7 or Miata or whatever
