Author Topic: heater went out all of a sudden  (Read 3984 times)
Denver Capri
« on: December 11, 2012, 07:04:00 PM »
Hello, today i was on my way to work and i had my heater on "high". i got pretty hot so i turned it completely off about 10 min later i went to turn it back on and nothing. no air flow. etc. iv checked some of the fuses i know of, and replaced one that was blown, but still nothing. please can someone shed some light, on this for me. i need my heater. asap. thank you
gary scott
  • TeamCapri Supporter
    • 1993 N/A blue / white soft / blue hard top
« Reply #1 on: December 11, 2012, 11:14:00 PM »
do you recall which fuse was replaced?
also,  can you hear the fan when you turn it on high?
Gary
Denver Capri
« Reply #2 on: December 12, 2012, 02:46:00 AM »
I checked the owners guide and I replaced the cigar fuse, and No the fan doesn't kick on at all.
« Reply #3 on: December 12, 2012, 10:31:00 AM »
Double check the fuses. Try applying power directly to the fan connector & see what happens. If it works there very carefully pull down the resistor pack and inspect the elements, it may have burned out.
The switch can go as well but it's unusual that it would fail on all the settings
gary scott
« Reply #4 on: December 12, 2012, 11:05:00 AM »
hi Denver Capri
there is also a heater breaker / reset switch next to the fuse box. if it has popped out press it back in. if it trips again when you turn the key, check for a short to ground.
if you search this site for word: 'heater a/c blower motor' under forum: 'capri n/a 89-94, 323 86-89' you'll see the resistor pack Rocketman  is talking about.
good luck
Gary
Denver Capri
« Reply #5 on: December 15, 2012, 04:49:00 AM »
Hey Guys, thanks for the tips ill give those a try later today or tomorrow. I work two night jobs so i sleep most of the day. But as soon as i get to look at it ill post my findings.
Denver Capri
« Reply #6 on: February 09, 2013, 10:07:00 AM »
Hey guys sorry it took so long to post my findings for the heater problem. I finally troubled shooted it about 3-4 weeks ago, well after 3 failed weekend attempts i was finally able to limit it down to a bad heater fan motor. A $125 later everything is running again.
« Reply #7 on: February 10, 2013, 12:30:00 AM »
OUCH...$125
Ask around next time first...You can get a used one much cheaper here.
