My B6T (still in the capri till I solve this, then on to the festy) has a throttle related stumble. If you ease into it from any RPM, it will accelerate (in neutral in the driveway as it has absolutely no brakes). However if you are more aggressive with the throttle, it will stumble (miss-fire?). From a higher RPM it will stumble and then recover and rev. Once it is revving (RPM increasing rapidly) all seams fine. Does brake up a little when you take your foot out of it and the butterfly closes.
Its got new plugs, wires, cap and rotar, air intake, new vacuum lines (most places, remaining look good), timing set to 12 (down from 22 ish before I touched it). Idle is at 850.
SO?
What do I do now?
And Thanks
