code: Gear set: Manually entered values Gear 1 2 3 4 5 Final Ratios: 3.307 1.833 1.233 0.970 0.795 3.850 RPM Limit: 6800 RPM @Peak Power: 5500 Tyre Size: 185/60 x 14 Tyre Diameter: 22.74 in Tyre Circumference: 71.44 in Gear Mph per 1000 RPM Mph @5500 RPM Mph @6800 RPM -------------------------------------------------------- 1 5.31 29 36 2 9.59 53 65 3 14.25 78 97 4 18.12 100 123 5 22.10 122 150 Mph RPM (in Gears) ------------------------------------------------- 1 2 3 4 5 ------------------------------------------------- 5 941 522 351 276 226 10 1882 1043 702 552 452 15 2823 1565 1053 828 679 20 3764 2086 1403 1104 905 25 4705 2608 1754 1380 1131 30 5646 3129 2105 1656 1357 35 6587 3651 2456 1932 1584 40 4173 2807 2208 1810 45 4694 3158 2484 2036 50 5216 3508 2760 2262 55 5737 3859 3036 2488 60 6259 4210 3312 2715 65 6780 4561 3588 2941 70 4912 3864 3167 75 5263 4140 3393 80 5614 4416 3619 85 5964 4692 3846 90 6315 4968 4072 95 6666 5244 4298 100 5520 4524 105 5796 4751 110 6072 4977 115 6348 5203 120 6624 5429 125 5655 130 5882 135 6108 140 6334 145 6560 150 6786 Gear Change RPM drop (change @5500) RPM drop (change @6800) ------------------------------------------------------------- 1 -> 2 -2451 (to 3049) -3031 (to 3769) 2 -> 3 -1800 (to 3700) -2226 (to 4574) 3 -> 4 -1173 (to 4327) -1450 (to 5350) 4 -> 5 -992 (to 4508) -1227 (to 5573)[/QUOTE]Here's with the 5th gear swap: code: Gear set: Manually entered values Gear 1 2 3 4 5 Final Ratios: 3.307 1.833 1.233 0.970 0.717 3.850 RPM Limit: 6800 RPM @Peak Power: 5500 Tyre Size: 185/60 x 14 Tyre Diameter: 22.74 in Tyre Circumference: 71.44 in Gear Mph per 1000 RPM Mph @5500 RPM Mph @6800 RPM -------------------------------------------------------- 1 5.31 29 36 2 9.59 53 65 3 14.25 78 97 4 18.12 100 123 5 24.51 135 167 Mph RPM (in Gears) ------------------------------------------------- 1 2 3 4 5 ------------------------------------------------- 5 941 522 351 276 204 10 1882 1043 702 552 408 15 2823 1565 1053 828 612 20 3764 2086 1403 1104 816 25 4705 2608 1754 1380 1020 30 5646 3129 2105 1656 1224 35 6587 3651 2456 1932 1428 40 4173 2807 2208 1632 45 4694 3158 2484 1836 50 5216 3508 2760 2040 55 5737 3859 3036 2244 60 6259 4210 3312 2448 65 6780 4561 3588 2652 70 4912 3864 2856 75 5263 4140 3060 80 5614 4416 3264 85 5964 4692 3468 90 6315 4968 3672 95 6666 5244 3876 100 5520 4080 105 5796 4284 110 6072 4488 115 6348 4692 120 6624 4896 125 5101 130 5305 135 5509 140 5713 145 5917 150 6121 155 6325 160 6529 165 6733 Gear Change RPM drop (change @5500) RPM drop (change @6800) ------------------------------------------------------------- 1 -> 2 -2451 (to 3049) -3031 (to 3769) 2 -> 3 -1800 (to 3700) -2226 (to 4574) 3 -> 4 -1173 (to 4327) -1450 (to 5350) 4 -> 5 -1435 (to 4065) -1774 (to 5026)[/QUOTE]Running 195/55/15's with a 7200 RPM limit you will redline 5th at 182mph.Of course I don't condone driving that fast, these cars get very scary at anything over 120mph
